Generating microsecond pulses
I am new to LabView and want to generate specific output signals. Everything >1ms works fine but is it also possible to generating pulses, with a pulse width of for example 500µs?
I am using the NI cDAQ-9178 with a "NI9474 DO24V Source High Speed" module.
Thank you
Chris
(5,517 Views)
Hi Chris,.
did you play with the example VIs for outputting digital waveforms with DAQmx?
(5,512 Views)
Where can i find it?
(5,509 Views)
Hi Chris,
in the example finder!
(The example finder is found in the help menu of LabVIEW… :D)
(5,506 Views)
Hello Chh2807,
attached a simple way i have done this
if only a PWM with frequency change is needed  i also attached a example.
best regards
Alexander
(5,433 Views)
Thank you very much for your examples. Now i have to try to understand that if this works for my needs. Thank you!
regards,
Chris
(5,370 Views)
Can someone explain how to modify the Generate DI with Time Continuous.vi to generate a single line pulse?  I keep getting an error indicating that the number of lines in the data for a channel does not match the number of lines in the channel. Please any assistance will be appreciated.
(4,447 Views)
