Genetic Algorithms
I am busy writing a genetic algorithm using C++ but I need to interface it with LabVIEW, as I will be controlling a laser from LabVIEW and the genetic algotihm will make up part of the closed loop system. Firstly, does anyone know how I would do this?
Secondly, is it possible to create a genetic algorithm in LabVIEW without the need for external code? Would anyone have an example of this if it has been done?
Alan Homer
(7,183 Views)
I'm not sure, but I think interfacing to LabVIEW from C++ would require you to create an ActiveX server or a DLL.
I have implemented a simple Genetic Algorithm in LabVIEW.
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(7,165 Views)
There is a genetic algorithm called 'Differential Evolution'.  I implemented it in Labview and it worked well for my purpose.
Under http://messages.info-labview.org/2005/01/20/27.html you will find a  link to the 'Differential Evolution' homepage where you can download my implementation.
-Franz
(7,148 Views)
Thanks for the advice.
(7,129 Views)
I found a working link to Differential Evolution, as mentioned by Franz, at this berkeley page
It looks very nice (haven't tried it yet)
Thanks Franz!
Message Edited by Paul Torek on 12-30-2008 04:29 PM
(6,303 Views)
