Genrating Sine signal to give it ot External circuit
I want to generate a Sine signal in LABView and give it as input to an external circuit, again the external circuit's output i need to give it to LABView how can i do it. And if i have to do any amplification or giving the signal to darlington pair can i do them in LABView before giving it as input..?
(2,339 Views)
Generating a sine wave is simple: just use Sine Waveform.vi (waveform->generation palettes)
As to getting it out of your PC to some external device and/or acquiring data from a device to your PC, that depends on the interfacing hardware you have and the drivers that are supplied with it.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,336 Views)
Okay, Then if i have DAQ how can i do it...
(2,312 Views)
