Geometry Classification
Heloo,
How do i build a programme with labview that can interrogate a part or the whole geometry to access if its suitable for machning in a 3 axis cnc router taking into consideration the limitations of the machining process. Thanks
(2,753 Views)
No idea.  That is too broad of a question to ask on these forums.
How To Ask Questions The Smart Way
These forums are here to help people answer their LabVIEW questions.  Not try to help you do your project for you.  You are probably the only person on the forums that is an expert in your subject on geometry and how it relates to CNC and the "limitations of the machining process".
I suggest you talk to the experts in your field about machining processes, CNC, and geometry.  Then figure out how you would program it in any language.  Then ask questions on how to that in LabVIEW.
(2,741 Views)
