Get Datatype fromTDMS
Hi all,
If I have a Channel name and the Group Name in a tdms file, is it possible to get the Datatype of a particular Channel?
Suresh Kumar.G
(3,419 Views)
Hi g_sures,
It's possible. You can view the TDMS in LabVIEW by using TDMS File Viewer in Programming -> File I/O -> TDM Streaming, when you view the channel in the viewer, it can display a property "NI_DataType" and this is the data type of the channel. You can also programming in LabVIEW by using TDMS Get Properties to get the value of this property in your code.
(3,396 Views)
