Get Date Time in seconds, replacing it from LV6.0 and LV7.0
I have got some sw in LV6.0 and I want to change it into LV7.0. The problem is the function " Get Date/ Time In Seconds". I don't know what is the data format of output of function "Get Date/ Time In Seconds" after I convert its output with the function To Double Precision Float. The LV7.0 help says:
"Returns a time stamp of the current time, measured as the number of complete seconds that have elapsed since 12:00 a.m., January 1, 1904, Universal time. Use the To Double Precision Float function to convert the time stamp value to a lower precision, floating-point number."
 Please see at pic: fcn_get_date_time_in_seconds.PNGIn LV6.0 it works good, but the same code in LV7.0 doesn't work good. What is wrong? Where is the best place to find help about it?
(2,671 Views)
The small black dots in the 7.0 version indicate that a data type conversion is performed: your Time_Begin and Time globals are not double precision variables.
Make them double precision and retry.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,668 Views)
thank you. you are right. it works goot now.
(2,656 Views)
