Get Err # 3"memory.c" line 461 when trying to save Test Executive VI for distribution
No LabVIEW_Failure_log.txt was generated. Same error occurs on all Callback and Test VIs.
(2,516 Views)
Install patch 2 for TestStand 1.0, available in the Related Links below. The problem should not exist in TestStand 1.0.1 nor in later versions of TestStand. You can order an upgrade to the latest version of TestStand by visiting the Upgrade Advisor, also linked below.
http://digital.ni.com/softlib.nsf/websearch/c7ce6def53882c73862566d6005dd1bf?OpenDocument
(2,516 Views)
