Get Free memory size
Hallo,
I'm developing an application and I want to reach the RAM limit (points on waveform graph)for different computers equipped with different memory sizes. Is there any way to know the computer free memory size at run time?
Many thanks
Neona
(3,393 Views)
hi,
you can call
VOID GlobalMemoryStatus(
LPMEMORYSTATUS lpBuffer // pointer to the memory status structure
from kernel32.dll. it fills a structure
typedef struct _MEMORYSTATUS { // mst
DWORD dwLength; // sizeof(MEMORYSTATUS)
DWORD dwMemoryLoad; // percent of memory in use
DWORD dwTotalPhys; // bytes of physical memory
DWORD dwAvailPhys; // free physical memory bytes
DWORD dwTotalPageFile; // bytes of paging file
DWORD dwAvailPageFile; // free bytes of paging file
DWORD dwTotalVirtual; // user bytes of address space
DWORD dwAvailVirtual; // free user bytes
} MEMORYSTATUS, *LPMEMORYSTATUS;
You may be interested in the elements dwTotalPhys and dwAvailPhys.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,382 Views)
