Get Image Subset VI ignores original image offset
I'm have a problem with Get Image Subset VI.
My program gets original image rectangle from a image and apply a offset for draw in a picture control.
But the image cannot across a region delimited by another rectangle. So, i use Get Image Subset with a
image (with offset) and a deilimiter rectangle.
I give the same subset of image with and without offset.
(3,178 Views)
Hi Bruno,
I just spent the last 6 months writting an app that made extensive use of "Get Image Subset " but unfortunately, I was not able to understand the nature of the issue you are describing.
Could you write some more about what you expect vs what you are seeing?
Just trying to help,
Ben
(3,167 Views)
In my opnion the correct result is the highlighted are in the Original Picture With Offset (See attached image ) and not Image Subset.
(3,153 Views)
