Get LV class name of a member VI
Is it possible to get a LV class name of a member VI?
For example:
ClassA
  • foo.vi
ClassA.foo.vi --> foo.getLVClassName returns ClassA
Balazs
(4,449 Views)
Balazs,
i assume that you want to do this programmatically and for an inheritance class hierarchy.
You can use the Get LV Class Path.vi and strip everything except the class name.
Norbert
Expert: Geometry
(4,445 Views)
Yes, I want to do this programmatically, but I have only a reference/path to foo.vi. So I would like to get it's class name through a property node or something like that.
Balazs
(4,371 Views)
Accepted by topic author BalazsB
Oops, i missed that there is a provided function called "Get LV Class Name"....
However, if you have a reference to a VI contained in a class, you can query the Library and then query the Name of the library using property nodes. Please make sure to close all references you create by these nodes in order to prevent a reference leak during execution.
Norbert
Expert: Geometry
(4,365 Views)
