Get Name from Event for using in state machine
Hello
I use a case loop to catch user events like pushing a button.
then from the eventloop i  start a statemachine. In some states i must decide which is next state in dependency of which event startet the state machine. I want to use the eventname for this.
 How can i get the event name of the eventloop?
thx simon
Using Labview 7.1
(3,195 Views)
I am confused by your description.
  • How many loops do you actually have? (You list "case loop" "eventloop", and "state machine")
  • Why do you use a "case loop" (whatevet that is)  to catch user events, wouldn't a loop with an event structure more appropriate for this?
  • Do you possible have an event case triggered by multiple controls and want to know which control triggered the event?
It would help if you could attach a simplified example so we understand your problem better. Thanks! 🙂
(3,187 Views)
The attached LV 7.1 example is a modification of the example that can be found at
labview\examples\general\uievents.llb
titled "Event Tracking"
This version illustrates how to distinguish between events from multiple controls that are handled by a single event.
I hope this helps,
Ben
Message Edited by Ben on 10-28-2006 11:54 AM
(3,183 Views)
