Get Object Reference by Bookmark ID
It is not clear where Bookmark ID (a U32 numeric) can be accessed to use the GetObjRefFromBkmrkID invoke node. I understand there is an app invoke node, "Get VI.Bookmarks" that outputs the "Bookmark Reference" (also a U32), is this equivalent to the VI Bookmark ID. So if name my book control is named #stop, use the App Bookmark Reference output into GetObjRefFromBkmrkID to get the control reference...correct or not?
I see David_L explains here but he's not clear on this issue.
(4,013 Views)
Correct.
He's pretty clear. It might be much to grasp if you're new to vi server, scripting or LabVIEW in general.
If you explain what you are trying to do and\or why your failing, we can help you out.
(3,963 Views)
