Get ROI and then use it in the program
My meter has 3 lines of data and to use Vision OCR, I want to select 3 ROIs using property node. I want the user to select ROIs from a sample image and then use the same in the later part of the code. Because of the data flow model of Labview, I'm unable to execute the ROI part first and then incorporate it into a part of the program. How do I control the flow of execution?
(3,243 Views)
Data dependencies. If you don't have natural dependencies, use the error clusters -- which you should be using anyway.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,208 Views)
Thank You
(3,196 Views)
Without seeing your code, it is difficult to make other than very vague suggestions (such as to use the Error Line to serialize some functions).  There are examples shipping with LabVIEW that show selecting ROIs and then using them ...
Bob Schor
(3,165 Views)
