Get Refnr to Excel using FindWindowA (.dll) Change in labview update?
Hi!
Are using Call Library Function Node (FindWindowA) to get the refnr to a Excel sheet. When I have change the code to LV8 and use the function (after a build) the function returns Error if the person is not an Administrator on the computer?
Any one the have had this problem or know a way around it?
(2,909 Views)
Hello!
I haven’t seen it reported before but on the other hand I guess it isn’t the most common application either! Obviously something has changed in LabVIEW 8.0 that makes things work out differently and one thing I know has caused ‘problems’ in various cases before has been the changes to application instances that we have done. It is not a bug or something it is just that in many cases people have been forced to change their code somewhat due to the changes we had to implement.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,888 Views)
