Get Status Register Rohde&Schwarz ESIB
Problem: I can not get the ESIB to send me the status register so I can determine if it is sweeping.
I'm not sure how else to get labview to do it. I even looked at the NI SPY and the analzyer isn't even replying aside from going into remote mode.
Message 1 of 10
(4,684 Views)
hi,
this should work.
regards juergen
Message 2 of 10
(4,654 Views)
juergenstraub wrote:
hi,
this should work.
regards juergen
Thanks I will give it a shot.
Message 3 of 10
(4,648 Views)
hi,
this should work.
regards juergen
hmmm it still returns a zero.
Message 4 of 10
(4,632 Views)
hmmm, what are you expecting?
Message 5 of 10
(4,628 Views)
a 3 weather it be a hex value for the register or not. The value 3 represents the register for Sweeping. The way I tested this is I started a sweep on the analzyer and then ran the vi which returned a zero which is cleary not the case since it was sweeping a 0 represents calibration. I am not even sure the commands are being read correctly.
Message 6 of 10
(4,618 Views)
hmmm... what do you want to do exactly, maybe there is another way to get to the same "result"?
regards
Message 7 of 10
(4,608 Views)
regards
Well simple really. I make the analzyer sweep for x amount of seconds I want the analzyer to finish sweeping completly once its finished I can capture a screenshot. I can do a work around by adding a delay which would provide enough time for the sweep to finish. However this method has a small problem, on the analzyer there is a status register which will display a red star on the plot when you capture a screen of the analzyer where the sweep isn't finished. This doesn't always happpen but when it does you must repeat the sweep; its no problem when your sweeps are 20 seconds but I tend to run sweeps of about 500-1200 seconds which is about 5-12 minutes which can be a bit of a pain.
Message 8 of 10
(4,602 Views)
use  SWEEP: SWEEP COUNT: {10} ENTER] (manual page 412)
via viWrite (...)
 >finish sweeping completly o
use  rsfsex_waitOPC(...)
this should work. regards
Message 9 of 10
(4,596 Views)
I will try that method and see how it turns out I will also update you on the results as well.
Message 10 of 10
(4,591 Views)
