Get Usable Monitor Size
You don't need the constructor. Drop a property node, right click, select CLASS / .NET then browse to System.Windows.Forms, then select SCREEN.
0xDEAD
Message 21 of 24
(1,857 Views)
Found this old thread today, looking for the topic. Just wanted to add that on my Windows 10 installation I cannot select any class and "Screen" isn't available at all.
Plus, none of the classes is accepted for the .NET property node because the OK remains locked.
Message 22 of 24
(1,451 Views)
You need to double click the System.Windows.Forms line so the + turns into a - and shows you the selections underneath it:
Message 23 of 24
(1,436 Views)
Years after this .NET process, AQ and Darren posted a G implementation that works pretty well over on LAVA.
https://lavag.org/topic/21484-need-way-in-g-to-get-monitor-size-minus-taskbar-os-independent/#commen...
I later turned that into some code that could center a window on the monitor your mouse is on, or center a window under your monitor, but stay within the monitor bounds.
https://lavag.org/topic/21678-what-determines-which-monitor-a-dialog-shows-on/?do=findComment&commen...
Message 24 of 24
(1,399 Views)
