Get VI Icon and Terminals Like in Context Help but in Runtime Engine
@7Ronin wrote:
@paul_cardinale wrote:
@7Ronin wrote:
Not Exactly....
The image I need is the one you would get if you were viewing the context help for a VI, that is the icon image and the terminals.
Also, I can't use scripting as this needs to work in the runtime environment.
Appreciate the suggestion though!
  1. When I run it, I get the icon image and the terminals.
  2. I tried compiling to to a .exe, and it still worked.
Sorry, I have to circle back to this.  What version of LabVIEW are you using?  I only get the icon terminal?????
Never mind- I was being dumb.  If you open a vi ref that has terminals it does indeed show them.  If you don't give it a vi ref it apparently uses a ref to itself.   Thanks again Darren and Paul.
-Nathan
Message 11 of 11
(224 Views)
