Get Volume Info.vi returns error 7 when trying to get disk information on cRIO-9025
Hi, Smiley Happy
I'm using a cRIO-9025 controller and wish to get the disk volume information of drive C: using the Get Volume Info function in the file I/O palette. When I run the function with the path as "C:\", the function returns an error 7 indicating that the path is incorrect.
I have used this function prior to this with cRIO but unfortunately I do not have any older devices with me to verify this now. I'm using LabVIEW 2009 SP1.
Many thanks!
Cheers!
Sankah2k
(3,714 Views)
I'm not sure whether c:\ is a valid path on CRIO,
the following code should get your paths:
Ton
My LabVIEW Ideas
(3,702 Views)
Accepted by topic author providev
On VxWorks real-time targets, the file path root is /c/ (in lower case). Try that and let us know if it works. You would be better of using the file path constant to figure out what the root directory path looks like.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,690 Views)
Thank you both for your great help! Smiley Very Happy
Managed to find that the path indeed was /c/
Cheers!
(3,653 Views)
