Get VolumeType
I'm trying to obtain the VolumeType of the diferent drives in my computer using Labview 8.6.1.
I have found that windows stores this info in a Class named DriveInfo: http://msdn.microsoft.com/en-us/library/hkk68fty.aspx
From this class can be obtained the property VolumeType: http://msdn.microsoft.com/en-us/library/system.io.driveinfo.drivetype.aspx
Is there any solution to obtain the same information in Labview? If not what can I do?
Thank you very much.
David
(3,024 Views)
Accepted by topic author DavidFG
An operation like that would require some sort of OS call. You could just call the .NET code directly, as shown in the attachment. The return value is an integer, but you can easily create a typedef enum that has the same enumerations as the DriveType enumeration.
(3,013 Views)
Thank you very much again.
David
(3,006 Views)
