Get a file from http to XML, parse the XML file and extract the data
@DavideBrusamolino02 wrote:
So you are telling that the "conversion" from html to XML is not done properly in labVIEW and this makes parsing the XML file more complicated?
There is no out of the box "HTML to XML" Converter in LabView  - just because you wish there was this out of the box solution doesn't mean you can force it by combing .vi's which are meant for a different purpose.
Message 11 of 12
(578 Views)
After some attempts i tried to do this, is a bit intricate to select and pass only the value i need but seems to work fine. Thank you.
Message 12 of 12
(558 Views)
