Get a p-v curve from a two-stroke engine.
I am trying to find an example program to find a pressure vs. volume curve for a two-stroke single cylinder engine.  I am using an optical encoder to measure the engine speed and a pressure transducer for my measurements.  I only have a beginner's knowledge of LabView programming so I wanted to see a similar example to use as a guide.  Thanks
Message 1 of 10
(4,071 Views)
Bulldawg,
Are you more interested in how to display data already acquired from your hardware or on how to use hardware to acquire the data?
Best Regards,
Chris C
Applications Engineering
Message 2 of 10
(4,050 Views)
I am trying to make a vi to get data from my hardware.
Regards
Message 3 of 10
(4,039 Views)
Plz describe your hardware.
From what it looks like you have to read one Analog input(probably volts) from a pressure transducer and a pulse output from an optical encoder.
So, if you eloberate on your hardware, we can suggest you better.
regards
Dev
Message 4 of 10
(4,031 Views)
From what it looks like you have to read one Analog input(probably volts) from a pressure transducer and a pulse intput (digital)from an optical encoder.
regards
Dev
Message 5 of 10
(4,032 Views)
Message 6 of 10
(4,023 Views)
I am using a Series E23 Dynapar brand optical encoder.  The encoder format is a two channel quadrature (AB) with optional Index (Z) outputs.  It has a 100 kHz frequency response.  The pressure transducer is an Optrand D32294-Q and has a 9-18V DC power supply and has one sensor output signal.  I am using a National Instruments SCB-68 breakout box to handle all of the wiring.  I am not sure what other information is needed to help.  Thank you in advance for your time in looking at this.
Regards
Message 7 of 10
(4,001 Views)
Could you also include what DAQ board you are using?  That will determine which hardware driver you can use.
Thanks!
Micaela N
Message 8 of 10
(3,973 Views)
can i know which DAQ card you are using?
Message 9 of 10
(3,952 Views)
We found another solution to the problem.  Thanks everyone for your help I appreciate it.
Best Regards
Message 10 of 10
(3,944 Views)
