Get coordinates of an element in an boolean array
Hi ...
How do I get coordinates of an element in an boolean array Control when the user click on it?
Is it possible ?
Please see attached image ...
(3,142 Views)
There are several solutions, the most advanced is on LAVA and should work for any array.
Register for the mouse-down event and feed the coordinates and a ref to the array control into the VI, and it returns the element clicked.
However it looks likeyou want to know which element was changed?
If so XOR the OLD and NEW value in a 'value change' event, this should have one 'T', using an iterative search you should have no issues finding that one value:
19365iAFAA8E9996C2FE41
Ton
My LabVIEW Ideas
(3,125 Views)
Thank you so much
I was tested your idea (based on old XOR new) befor. But there are some problems in my program ...
Can you explain second solution further more ? This way brings back coordinates of situation of the mouse in screen. NOT coordinates of element. ???
And I got LAVA's program too. But I could not understand what does this program do !
Excuse me for my bad english
(3,083 Views)
Here's how you would use the LAVA program:
19471iDE660682B9EB1F11
Here's a snippet containing both methods:
19473i7F4AEA3C3A0AB727
Ton
My LabVIEW Ideas
(3,075 Views)
