Get data from hysys to labview
This is my first time using Labview so I am not familiar with it. I am a Chemical Engineer working on a project, I have used HYSYS to simulate process dynamic, the current project I am working on is to creat link between hysys and labview to visualize all parameter on labview such as
Pressure Indicator Controllers, Temperature Indicator Controllers and Level Indicator Controllers, I saw a project like this on youtube ( https://www.youtube.com/watch?v=pnSUygeoRUM&t=515s ). Thanks in advance.
(2,435 Views)
Are you planning on spending the time to become a competent LabVIEW developer?  If not, ask around to your Engineering colleagues to see if any of them have significant LabVIEW experience and can help you get started.  If you want to learn, there are suggested Tutorials and other material on the first page of this Forum.
Bob Schor
(2,391 Views)
I want to learn how to do it, and where i can found tutorials in the forum please.
Thank you so much
(2,376 Views)
Hi Farid,
you find tutorials in the header of the LabVIEW board - right under the header line "LabVIEW Training resources"…
(2,369 Views)
