Get graph coordinates of XY Plot - Graphics Function
Hello, I use the XY Plot - Function from Graphics and Sounds, to generate a graph on a picture. Now I want to mark a specific data-point on this graph, but I only have the real coordinates but not the dots. To convert an orginal data point to dots I would need to get the active plotted area used on the picture (the start of the axis). But how will I get it? See the picture for more detail. -> I need to know the place of the red area. thx. Philipp
Message 1 of 12
(7,711 Views)
Is the property "position" enough for you? You now how to create it?
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 12
(7,703 Views)
Unfortunatelly not. I do not need the position of the graph. I need to know f.e. the position where the X and Y axis meet. With the property you mentioned, I can only set where the whole graph (including everything) starts. I need to know the area you can see in the picture.
Message 3 of 12
(7,694 Views)
OK.
And other thing. That space between the property that i've mentioned and the one that you want isn't it steady? If so, with a few tries you can determine the things that you want. no?
Software developer
PORTUGAL
Message 4 of 12
(7,686 Views)
Right. But the spaces changes, each time the number becomes higher one decade.
Message 5 of 12
(7,681 Views)
Well, I've no idea left.
You don't use the xy graph by a good reason, right?
Software developer
PORTUGAL
Message 6 of 12
(7,679 Views)
I also use the XY-Plot, but i have to make a report with a protocol out of the XY-Plot. The notes made in the XY-Plot should be included in the protocol, but to do so, I have to re-draw them in the Graphic. I can not use the export to graphic property node of the XY-Plot, because there has to be a frame and text around the Graph.
Message 7 of 12
(7,672 Views)
ok,
But let me give you another tip. You use the normal XY graph. And put all the things that you want to appear to your report on a tab control. then export this tab control using the "export image" invoke node. No?
Software developer
PORTUGAL
Message 8 of 12
(7,661 Views)
sounds quite good. how does this work? Could you make just a short example of the invoke node? is the picture an emf file? Is it possible to make this in black and white?
Message 9 of 12
(7,652 Views)
See my old post:
http://forums.ni.com/ni/board/message?board.id=170&message.id=232004#M232004
Software developer
PORTUGAL
Message 10 of 12
(7,640 Views)
