Get list and load vi included into a project folder on labview RT
I need to get the list and load the Vis included into a folder under Labview RT Project explorer.
I know how to do this on labview but not under Labview RT.
The thing is that physically these Vis are on the host but once I create an executable, theses Vis are permanently deployed on the target.
As an example, on the picture I'd like to get the name of the fourth files named fichesX.vi, displays it and load the one I've selected.
How can I do this?
I don't think I'm very clear.
James
(3,032 Views)
Hi James,
as far as i know there are some properties with which you can get a list of all folders and vi´s in your project, also them in other targets.
Mike
(3,020 Views)
Hi Mike,
I agree, but I can't find which ones.
Can you tell me which one I should use?
Thanks a lot
(3,006 Views)
Hi James,
please try the properties from the attached vi. I know there are some bugs in the code, but you have the properties you need. Smiley Wink
Hope it helps.
Mike
(2,998 Views)
 Hi Mike,
I'm sorry but I don't see how to do this. I try many property but I can't get list of vi!!!
any help?
thanks
(2,966 Views)
