Get menu problem!
When I try to get the information regarding a selected menu item using the Get Menu Item Info, I am getting the followintg error:
"Error 1162 in Get Menu Item Info in .vi
Reason: Cannot find one or more tags".
Surprisingly, I am working with this project for quite sometime and I am facing this problem today only and not before. And also, there is another project for which the menu.rtm is same as this file(filename and other operations are different)but it runs without showing any error. I don't know whether there is any bug with LabVIEW or with my program. I have attached the required file. Run the MenuTest.vi and try to access the menus and please help me to get out this unknown error.
Thanx & Regards,
Srini.
(3,237 Views)
You should not wire a "Get menu item info" in the "default" case !
Chilly Charly    (aka CC)
(3,237 Views)
