Get mouse cursor position error by the WIN API function
I get the mouse cursor position error by the Win API function,my OS is WIN 7(64 Bit).But I use the LabVIEW functions is OK.
(4,173 Views)
Accepted by topic author weschen
Hi weschen,
do you mind to unlock the VI or to provide the password you used to lock it?
Are you sure you call that GetCursorPos function in User32.dll the correct way?
Your CLFN setup doesn't follow the Microsoft manual…
(4,140 Views)
Thanks,the parameter lpPoint is struct(LPPOINT),my CLFN setup is wrong.The vi file of attachment is OK(removed the password).
(4,132 Views)
