Get numerical values from 2D array of string
Hello!
I start by saying that I have a base knowledge of LabView. I'm using LabView 2011. I'm doing some communications test via Can-Bus protocol. As you can see in pictures of the block diagram and of the front panel that I've attached I'm using "Transmit Receive same Port" LabView example. It works very good but I would need to insert the 8 data bytes that I receive from the server in 8 different numerical variables so that I could use them to make some operations. How can I get numerical values from the 2D array of string that I attached?
Every example that you can provide is important!
Thank you very much!
(3,373 Views)
duplicate post, continue here!
(3,366 Views)
Sorry. I'm trying to remove the other post
(3,362 Views)
