Get parameters from MAX scales
Hi
I'm trying to read the parameters of a scale that has been created in MAX.
I can get a list of the scales stored in MAX but when it try to read the "scale type" of the "ActiveScale" I get an error.
What I have planned to do is to collect the parameters of the scales such as slop, intercept and so on.
Thanks for any help
Yves
(2,845 Views)
Accepted by topic author Yves
Hi!
I've tried with this simple VI and everything is fine for me (LV2011).
Can you give more infos about your problem?
Marco
(2,831 Views)
This is really odd. I had the same solution but it didn't work.
I had even tried to separate "ActiveScale" and "Scale Type".
But with your vi it works.
Thank for your help.
Yves
(2,816 Views)
