Get physical channels control into separate strings
I have a physical channel control with "Dev1/ai0:1" and I wish to separate this to two strings or two channel controls, for instance, turn this Dev1/ai0:1 into this Dev1/ai0 and this Dev1/ai1 programaticaly.
Thanks.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
(4,008 Views)
Accepted by topic author Daniel Coelho
Hi Daniel,
you can use the Match pattern function to get both numbers. Convert the result strings to numbers, subtract the smaller from the larger one, add 1 and run a loop result times in which you create your string.
Mike
Message Edited by MikeS81 on 11-27-2008 04:29 PM
(4,005 Views)
Thanks Mike,
I did something similar but I was looking for a LabVIEW funcionality to do it.
Maybe there isn't.
Thank you for your quick reply and for your sugestion, it works fine.
Daniel Coelho
Daniel Coelho
(3,999 Views)
I forgot, this is my VI just in case someone needs.
Daniel Coelho
Daniel Coelho
(3,998 Views)
Just use the DAQmx Unflatten Channel String function. It's on the Measurement I/O>DAQmx Advanced>DAQmx Utilities palette.
(3,975 Views)
Thank you Dennis. That is exactly what I was looking for.
I already gave the solution tag on this post but this is the the answer I wanted.
Daniel Coelho
Daniel Coelho
(3,943 Views)
