Get "memory used" by an EXE
Hi all,
Due to my hardware and software configuration, the EXE I built with LabVIEW 7.1.1 can not use more than 2Go of RAM.
The computer has 4Go and only runs my EXE so when I allocate memory for images (close to 2Go) LabVIEW can find contiguous memory.
Now I'd like to push the management of memory a step further from inside my EXE, so to know how much memory I can allocate, I need to know how much my EXE is using befrore trying to allocate ; in gfact exactly what I see in the task manager.
How can I do that ? I Guess .net could do that, or a dll call (maybe kernel32.dll or system32.dll) or a dos command. Smiley Surprised
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,349 Views)
As you are running on Windows, a very simple way to do this is to use System Exec and issue the "tasklist" command. This outputs a table that lists the processes and the memory usage. You can easily parse this string for your app.
(3,314 Views)
Thanks a lot, this is exactly what I need !
Epictetus
Antoine Chalons
(3,308 Views)
