Get screen capture during other app running
hi, Expert,
I want to catch screen capture during other test app running, could you help to see my code and why i cannot got a fixed window location pic,
I also found a NI example 2012, this is full screen capture, could you also help to modify to my target app,
example like if i want to capture Excel, then it can pull Excel window in front and only capture this window without background, if i choose another .exe window, it also works. OR fix a screen location like X,Y,top, bottom, etc .
Elena
(235 Views)
Hi elena,
Once you got the fullscreen snapshot as image you can easily use image functions to crop the image as needed…
(207 Views)
If your target window is active window, you can simulate alt+printscreen to capture just the active window.
Can't open the attached VIs, which is actually in LabVIEW 2019.
George Zou
(170 Views)
