Get string inside brackets - Using Scan from string
I have a very basic question here. I would like extract a portion of a string which is inside brackets (Example: I work with [National Instruments]). In the string I only want to extract National Instruments, I do know logic to extract by finding the brackets and extracting them. But I am interested in using the Scan from string or possibly any other primitive in one shot. Please suggest if anyone has any idea, I am really not use to the format specifiers. I got this link for reference but I am not able to figure out a solution.
(9,405 Views)
Accepted by topic author P@Anand
(9,384 Views)
Thank you.
(9,372 Views)
I cannot say that it is the best solution, I use two Scan From String functions instead of one but it does work, so far 😉
I use Characters in set.
I could not attach VI so FP is below.
Duri
(9,369 Views)
I did this already and got it working. But earlier I have seen extracting the string using a single primitive and thats why I posted specifically for that. Thanks for the response.
(9,365 Views)
last try 🙂
Duri
(9,340 Views)
