08-01-2007 11:53 AM
12-11-2007 07:32 AM
01-21-2008 04:25 AM
"Hi,
http://tolstoy.newcastle.edu.au/R/e2/help/07/04/14898.html
"Hi, "From Matlab v7, _compressed_ MAT version 5 files are used by default [3]. These are not s... You haven't told use what version of R you are using (neither what version of R.matlab), but from the error message I suspect you are using Matlab v7, correct? If so, try to save with save('test.mat', 'matrixM', '-ascii', '-V6') and tell us if it works. Cheers Henrik "
01-21-2008 07:53 AM
01-23-2008 01:13 PM
01-23-2008 02:51 PM
01-24-2008 01:03 AM
01-24-2008 06:59 AM
01-24-2008 07:37 AM - edited 01-24-2008 07:39 AM
01-24-2008 11:52 AM
Dear ThSa,
Using your attached tdm files, and vi's, I got the correct time stamp in the minimum and maximum values, as you suggested!
The problem is, that using the same settings (X Value Columns etc.) on saving a _TDMS file_ rather than a TDM file, I get 0 values in both
minvalue and maxvalue on the MATLAB script
Do you have any idea why this occurs? Can you check it on your platform?
I may switch to using to TDM instead of TDMS, is there any advantage to using TDMS rather than TDM? I am recording just one channel at around 1000 Hz for about a 1000 seconds
Thanks dearly, WildCherry
