Get x-axis value (time) of waveform chart
I am plotting some temperatures (multiple plots) on a waveform chart. I would like to save the actual value of a
plot (temperature:y scale and time: x scale), when pressing a button, to a spreadsheet file. So in the spreadsheet
I would have the temperature and the time value, at the point when I pressed the button.
I can get the temperature easily by the property node value, unbundle the cluster and save the respective value to a spreadsheet. But how to get
the time value at that temperature point.
I know the time value must be also there, because I am saving the whole dataset to a measuring file and then I can display
it in a graph.
Cheers Patrick
Message 1 of 10
(15,170 Views)
Accepted by topic author pat777
Considering a Chart is evenly spread on the X-axis so the X-distance between 2 points is the same every where.
What you could do is create a property node and determine the min. and max range of the X-axis.  and you know the number of points of your array(history).
That way it's really easy do determine the times 😉
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 10
(15,168 Views)
I like Bjorn's idea! That is probably a better way of handling this. Howver, if you want to keep things simple, have your DAQ task return a waveform... even if it is only return single temperature values. Normally waveforms are reserved for higher speed acquisitions, when the data task returns larges areas of values. But, in this instance they may be very useful, as the waveform datatype includes bit value and a time stamp.
Please see the attached screen captures and .vi.
Now you have programatic access to the temperature and time values, which can be easily saved to disk when you hit a save button on your front panel. Also, this idea is easy to scale for multichannel DAQ.
Hope this has been useful.
Best wishes,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
Message 3 of 10
(15,146 Views)
Hi Bjorn,
Thanks for your answer.
Actually, in my case it is sufficient to use the property node:max range x axis.
My plot range is 100 sec, but I am logging the time every three minute so my max range is updating with the chart.
In case I want to plot some before the first 100 sec are over I use the size of the history array, divided by my sampling rate, e.g..
10 per sec.
Thanks again and Best Regards
Patrick
Message 4 of 10
(15,112 Views)
Hi Rich,
Thanks for your answer but I already had Bjorns idea implemented, so I did not tried out yours.
Cheers
Patrick
Message 5 of 10
(15,110 Views)
Anytime Patrick,  glad I could help
Kind regards,
- Bjorn -
Message 6 of 10
(15,109 Views)
Hi:
I have a waveform which has Y-axis as Amplitude and X-Axis as Time.
Now since we are using an ultrasound sensor for plotting the waveforms i need to see distance on X-Axis and Voltage Amplitude on Y-Axis.
Can anyone suggest how we can do this in LabVIEW 8.6.
Dhananjay
Message 7 of 10
(13,918 Views)
[edit: posted in error]
"If anyone needs me, I'll be in the Angry Dome!"
Message 8 of 10
(13,913 Views)
Is there a version for LabView 8.2?
Message 9 of 10
(13,786 Views)
Do you mean a version of RER's posted VI?
If so, then you can post a request for a downconvert to 8.2 in the Version Conversion board
-CC
Message 10 of 10
(13,781 Views)
