GetTitleBarInfo function user32.dll Windows API
Hi guys,
I've a proble with some Windows API functions.(GetTitleBarInfo for example).This function needs parameter a struct pointer that than allows me to get the tiitle bar name.Ok ,but How i can handle a struct point?In Reference guide says to treat Pointer as integer but i not understand how do to reach my purpose.
Luca.
(5,485 Views)
Are you trying to get the title bar of a LabVIEW window? You do not need to use the Windows API for that. The Front Panel Window:Title Property will tell you that.
(5,483 Views)
Hi sMercurio,thanks for the fast answer.
No,my purpose is to get the window title bar of other application running.
Luca.
(5,477 Views)
For most things Windows API related I suggest the following document:
https://forums.ni.com/t5/Example-Code/Windows-API-Function-Utilities-32-bit-for-LabVIEW/ta-p/3501597
In this case you just need to construct the proper cluster to get the info:
(5,473 Views)
Cool,it is what i want to find.Thank you very much.Only one thing: when you set argument and parameter function in dialog box relative to API nodenin labview,which data type use to represent a pointer to struct?
(5,462 Views)
For a pointer to a structure you need to set the parameter to Adapt To Type and make sure to construct a cluster that matches the structure exactly. Some C programming knowledge is definitely helpful and for more complex structures really unavoidable.
Rolf Kalbermatter  My Blog
(5,450 Views)
