GetTypedefPath.vi
I found this vi in hidden gens, it would be quite usefulin my application. When testing I always get an error... Any ideas why?
Message 1 of 8
(5,638 Views)
right-click the type def.. choose open type def.. save the type def.
Try the code again?
Ben
Message 2 of 8
(5,636 Views)
Tried but no succes. I am using LV2014. Ctl was saved on disk before so what is the point in doing that again?
Message 3 of 8
(5,634 Views)
To rule the possiblity that the type def had never been saved.
Ben
Message 4 of 8
(5,630 Views)
I don't think that is the case. I have checked that name is inside variant:2016-08-10 22_04_23-Untitled 9 Front Panel _.png
Message 5 of 8
(5,619 Views)
Well, this seemed like a No-Brainer -- this just has to work, doesn't it?  Well, I can tell you that in LabVIEW 2014 (which the Poster was using), I could not get it to work.  However, I noticed in LabVIEW 2016, it is not listed in "Hidden Gems", so I thought, "Aha, it doesn't work, so they took it out!".  But most of the Variant utilities are missing -- turns out they've mostly been moved to the Variant Palette.
So while I have no idea why the same code fails in LabVIEW 2014, I can tell you that it works just fine in LabVIEW 2016.
When I ran this, it gave me no error, and the Path it returned indeed pointed to the path of this TypeDef.  Caveat -- I did have the Project open at the time.  Just a sec, let me close the Project and try again ...  Yep, it still works, even with the Project closed.
Bob Schor
Message 6 of 8
(5,606 Views)
It is a real possibility that the 2014 version was buggy.  I mean it wasn't on the palette for a reason right?  I've used this function sucessfully in 2015, but don't have 2014 to test with.
Message 7 of 8
(5,600 Views)
Thanks, will have to install new LV version sooner or later ... 🙂
Message 8 of 8
(5,594 Views)
