Getting 1043 error in a development configuration
I have a simple VI running on a cFP system.  To run in the development configuration, I run the VI under the cFP target.  But now I'm trying to build an application executable for the customer.  I've created a simple VI (attached) that is supposed to open the front panel of the target VI and run it.  But when I run this I get the 1043 error saying the invoke node isn't available: "LabVIEW:  The property or method is not supported in this version of LabVIEW.
Method Name: Front Panel:Open"
When I looked this error up, it sounded like a problem with trying to call the invoke node in the run time engine but it should work in the development configuration.  But of course, I need it to work in BOTH configurations.
How do I create an exe for the host PC that will pop open the VI on the target and run?
(3,036 Views)
knicewar,
You're seeing this error because this functionality is not available on a real time system.  Generally, if you need to monitor a front panel on a real time system you will either need to create a remote front panel, or you will need to build a "monitor VI" that will read elements from your cFP system through either a queue or shared variables.
ColeR
Field Engineer
(3,008 Views)
