Getting Cluster Info from a Reference
I want to do this:
But it works only if the referenced cluster doesn't contain a boolean with latching action.
Is there a workaround to get cluster info from a reference to a cluster that does have a a boolean with latching action?
(2,130 Views)
@paul_cardinale wrote:
I want to do this:
It seems to work if you use the Value property node instead of Get refnum, with the caveat that it's slow.
Qestit Systems
Certified-LabVIEW-Developer
(2,126 Views)
I want to do this:
Unfortunately the won't work for me because the value of the ref is 0 (not a ref).  I'm trying to extract type information from a refnum inside a variant when the refnum is invalid.
(2,093 Views)
To get the data type information you either need a strict reference (not possible with a latching boolean) or a valid refnum so you can parse the information from a different property such as Value or Terminal.Data Type.  In this case it looks like you are trying to get data that simply isn't there.
I understand the siren song, but Clusters are ill-equipped as UI elements, and latching is definitely a UI functionality.
(2,073 Views)
