Getting Eigenvectors of a large array for PCA analysis
I am writing code for PCA analysis based on Karhunen-Loeve decomposition. This involves getting eigenvalues and eigenvectors of a very large array i.e. 944x944. I'm getting the error -20062 which indicates that I have exceeded the maximum iterations of this VI. Does anyone have a suggestion as to what I may do from here, besides using different software, or is this my only choice? Thanks in advance.
Marion
(3,292 Views)
I tried to reproduce the problem in LabVIEW 6.1 and 7. It seemed to work in both versions. My test code in LV 7 is below. Can you post simple code that reproduces the problem? You will probably want to let NI know about the issue. Goto www.ni.com/ask to contact them. I know of no workarounds.
(3,292 Views)
Thanks for your reply Jeremy. I can't open your code because I am working in Labview6.i. However I have written a vi with just the array I am using and the eigenvector/value VI. It runs for a few secs then just stops and nothing is written into the output arrays!
(3,292 Views)
This code looks like mine except there are no default values on the 2d array. It is behaving really strange. In LabVIEW 6.1, I created a two nested for loops and added their i's to create the 945X945 matrix. The first time I ran the code, it did not return anything. The second time I ran the code, I hooked up the error output and closed down the windows for "eigenvalue and vector.vi" and it worked!! I saved for previous and the code worked in LabVIEW 6i. I am not sure what is causing the problem.
(3,292 Views)
Hi Jeremy,
Thanks for trying again. I have given up and resorted to using Matlab instead. It's working fine now but I have to export my eigenvalues from Matlab to a spread sheet. I can't use matlab script because for some other bizarre reason when I put the eig(); instruction in a Matlab script in Labview it also crashes. It doesn't seem to like Vector Analysis!
You've been very kind.
(3,292 Views)
