Getting Error 2 while attempting to compile a large LabView 8.0 project.
Error 2 occurred at ABAPI Dist disconnect td-poly.vi -> ABAPI Dist Chg and Save VIs.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Memory is full.
NI-488:  No Listeners on the GPIB.
(2,694 Views)
It appears that this can be an issue when building large VIs into executables on a 32 bit operating system. Please see the KnowledgeBase article below for explanations and a possible workaround.
http://digital.ni.com/public.nsf/allkb/CBEBDC184655FC8C8625724A00050854?OpenDocument
(2,666 Views)
Will implement the KnowledgeBase article on creating a smaller exe.
 Thank you for the reply,
 rjhaze
(2,662 Views)
