Getting Library Function Call errors!
Just recently, we've been trying to upgrade our testers to an Analogic Digitizer which uses Dll files for programming. So we've modified our test code with the appropriate library function calls and have tried to run the software via our labview test executive.
It seems that when we run the new software via the test executive, we see errors induced in the operation of our Asset 3.1.1 Boundary Scan Library function calls...? These older Asset LFC's have not been modified with the latest upgrades and are currently running with the older version of production test software without issues.
I'm thinking we've run into a memory constraint of some type that my be due to the 5.1.1 version of LabView software. Could you tell me if th
ere are
any memory constraints with this version of Labview...? If there's a limitation to the number of vi's and/or library function calls that can be
contained within a single library...?
We are trying to run the software via a library without diagrams...
Could you also give me the name and number of your nearest technical representative so I may be able to hash this out with him/her over the phone if need be...?
Message 1 of 1
(2,646 Views)
