Getting Script Error in LabVIEW Help
In LabVIEW 2010 I'm getting a Script Error when I try and Open Example on page Property Node (XML).
See attached PNG file.
What's causing this error?
How can I access the Example?
(4,561 Views)
I am also getting it when I try and open example on page "Flatten To XML Function".
What is wrong with these XML examples?
How do access these Examples?
(4,557 Views)
I have no problem opening the example for the flatten function. I don't see an example available for the property node. You're doing a right click and selecting 'Examples' and then clicking on 'Open Example'?
(4,548 Views)
I am in LabVIEW 2010. If I go to my Block diagram and select a Flatten to XML function with Context Help showing. I then select Detailed Help link. In Detailed Help page I Left mouse button click the Open Example icon. That's when I get the script errror.
(4,542 Views)
It works just fine for me. Is your help file in the location that the error message lists? Can you launch any examples from the Context Help window?
(4,534 Views)
I have not moved any of the Help files. They are in their installed locations. I have been able to open other examples until I tried these XML related examples.
Why are the errors recorded a script errors?
If it can not find a file, how can I tel what file and where it is looking?
(4,531 Views)
You can always do a search in the example finder. Sorry, but I have no idea why some examples can be found but not others.
(4,525 Views)
