Getting Structur into the Forntpanel by using dorpdown list
Hallo,
i have 21 diffrent LED Channel with Spectral Data graphs plus some more nummeric indicator. My plan was first to creat 21 tabs in a tab control, so each tab can show the data form one channel.
Is there a way to do this with a dropdown list, so i select a channel an it automaticly shows me the Graph and the nummeric data. Would be also nice if i only have to creat one nummeric indicator for all Channels.
For exemple: Each channel has a MeanWavelenght, so i dont want to creat a 21 MeanWavelenght indicator, just one. This one Indicator should show the value of the selectet Channel.
Thanks for you help
Felix
(2,154 Views)
I would guess that it is definitely possible. Post some examples of what your graphs and data look like at the moment (As a VI not a picture) and you will probably get some sensible suggestions.
(2,152 Views)
@felixfelex wrote:
Hallo,
Thanks for you help
Felix
You can proceed with the tab idea.  In the tab's right-click menu, select "Visible".  You will see that you can make the tabs not visible, and you can instead use a selector - Page Labels Display - to select the tabs.
Is that a good compromise?
Edit:
Oops, I only answered the first question.
Bill
CLD
(Mid-Level minion.)
(2,120 Views)
Accepted by topic author felixfelex
Try something like this.
(2,106 Views)
Thanks alot,
that is perfect for my need.
Greets
Felix
(2,063 Views)
