Getting a -1074118656 ni DMM driver error
I am Having an error code -1074118656 and the message saying  that the error occurred at niDMM Initialize.vi. The driver is working good in NIMAX . The front panel of the DMM is working good in the NIMAX.
Message 1 of 11
(5,795 Views)
Most "Initialize" VI's have two options "Reset" and "ID Querry", and most times these options are enabled by default.
If your instrument identifies even slightly different than what the VI is looking for (like model#) it will fail the ID querry and probably give an error similar to what you are seeing
=== Engineer Ambiguously ===
Message 2 of 11
(5,759 Views)
how I can check that?  I cannot find the DMM initialize.VI
Message 3 of 11
(5,755 Views)
It's not part of your program?
http://zone.ni.com/reference/en-XX/help/370384N-01/dmmviref/nidmm_initialize/
Message 4 of 11
(5,750 Views)
I am not the programmer of this software plus I am new self learning LabVIEW and I need to get this working.
Message 5 of 11
(5,745 Views)
Usually if you stop the program when the error occurs LabVIEW will open the block diagram and highlight the part in the code that had the error.
Other than that you could use the "Find and Replace" function on the block diagram to find the VI.
Find and Replace is in the Edit menu.
Message 6 of 11
(5,743 Views)
Accepted by topic author ZiadAlkhoury
Thank you all for your time and consideration. I did find the issue and the solution was that the global destination for the DMM was incorrect so I changed it and saved it all.
Message 7 of 11
(5,637 Views)
Whats a "global destination"?
Message 8 of 11
(5,626 Views)
it is the path or the VISA for the DMM was entered as a global destination path.
Message 9 of 11
(5,624 Views)
Oh, you mean the VISA resource?
Like the com port or GPIB address?
Message 10 of 11
(5,621 Views)
