Getting a case structure process to repeat.
I am looking to get the process that happens in the case structure to repeat or have the value of the iterations reset to 0. I need the case structure to repeat the pattern that it currently makes several hundred times but right now it just stops after 65 and runs the default value. I know there are issues with the proximity sensor portion of my code, please don't focus on that, I need help with the case structure stuff. Thanks in advance.
(3,180 Views)
Accepted by topic author JRyno
Hi JRyno,
I guess you are talking about the case structure with cases like "55, Default" - and not those other 3 case structures…
That's not possible, that "iterator" will always count up (to a limit of 2^31-1)…
BUT:
  • You can make your own counter using a shift register.
  • You can use the Quotient&Remainder (aka modulo) operation to limit the counting range…
(3,175 Views)
Yes I am referencing the case structure that has 55 set as its default.
When you say using the quotient&remainder operation to limit the counting range would that be the counting range for the iterations?
And ok I'll work on my own counter with a reset when it hits a certain number, thanks.
(3,171 Views)
Hi JRyno,
Something like this:
(3,164 Views)
Thanks, sometimes there's a solution so simple you don't even think about it.
(3,160 Views)
