Getting all the Tables from a particular MS Access Database
Hi everyone,
I like to know how to get all the table names in a particular Database(MS Access) through query commands..
If anybody have some solution, kindly share with me !
Thanks in advance.
(3,535 Views)
Accepted by topic author VeeBee
Are you using the Database Connectivity Toolkit? If so, use the DB Tools List Tables function from the Utility sub-palette.
(3,528 Views)
@VeeBee wrote:
Hi everyone,
Thanks in advance.
If you don't have the Database Connectivity Toolkit, then you had better brush up on SQL since this is not a LabVIEW problem.
(3,525 Views)
Dear Phillip,
Thanks a lot for the vital information.
I was not aware of the palette function & had been searching in the Query commands.
Veebee
(3,493 Views)
Hi Nyc,
Thanks for the suggestion.
The palette function as mentioned above by Phillip satisfies the requirement, that is found in the database Toolkit.
Just, I wanted to let you also know about this.
Veebee
(3,492 Views)
@VeeBee wrote:
Hi Nyc,
Veebee
I don't need to know about this.
As I wrote above if you have the Toolkit you should look in there first.
I have no way of knowing whether you have the Toolkit or not.
(3,484 Views)
Thanks for the information!!
http://www.cimaware.com
(3,268 Views)
