Getting an error trying to install software via MAX on a cRIO 9036 Labview 2017
Hello:
I'm getting an error when I try to setup a new cRIO 9036.  During the software install using NI MAX, the install fails at the same spot. it occurs when installing Current Component: Module Versioning Tools. Running installation script : /mnt/userfs/.syscfg/(281BSF03-4DD8-8895-8CB004473F3A)/postinst_versioning.utls.
I tried uninstalling LabVIEW from my PC and reinstalling.  Another potential cause seems to be a firewall issue.  I set the required ports to be opened and allowed MAX through the firewall but the error is still occurring. Previous to this issue, I've setup several cRIOs with this issue never occurring before.  I'm not sure if its a LabVIEW installation issue or if its a draconian firewall issue which my company might have recently implemented or if its something else entirely.
LabVIEW 2017 SP1 Professional Development Suite
Real-Time Module
FPGA module
OPC UA
The error I'm getting is:
Execution of external command, script, or application failed.
Thank you for any help
Message 1 of 1
(2,378 Views)
