Getting degrees of arc from LabView
I have an application in which I need to obtain the tilt angle of a sensor package based on X axis and Z axis accelerometer data. How do I convert the tangent of X/Z to degrees? This would normally be the arctangent of X/Z but the ATAN trigonometric function in LabView does not do this. Anyone out there have an example in LabView version 8.2?
(3,480 Views)
Multiply the result by 180 over pi Smiley Wink
Message Edited by Ravens Fan on 09-10-2008 10:36 PM
(3,471 Views)
Thanks. I don't know why they couldn't have provided this as a separate output from the VI.  I haven't worked with Trigonometry for a long time, otherwise I might have figured it out myself.
(3,451 Views)
It is just like Excel in that regard.  All the trig functions are based on angles computed in radians.
(3,428 Views)
