This widget could not be displayed.
Getting duplicate (x10) readings from the "format date time string" function to the "TDSM write"
Hey folks!
I've got my first labview task. I'm very unexperienced with the software so note that the solution could be something obvious I've overlooked.
I've attached the VI (drive link) for you to try yourself. You have to input runtime (10-20s) and frequency (200-500ms) on the front panel. Also you have to choose an empty tdms file as a path, also in the front panel.
My problem before this is finished, is that the time and date is repeated an average of 10 times before it continues (shown in picture). The time/date should only sample and write 1 time before it "moves on" sampling and writing the data values.
NB: I'm aware that the DAQ assistant does the logging automatically, but it's insufficient for this project.
Message 1 of 11
(2,408 Views)
Hi boyy,
You are writing the same timestamp to the TDMS file several times inside the loop.
And this loop may iterate very fast several times due to those autoindexing inputs - faster than the clock will update. (Especially as you write only 3 digits for milliseconds…)
Please attach all files directly to your message in this forum!
Most people refuse to open 3rd party download links, many people are prohibited from opening such 3rd party download links (due to company firewalls)…
Message 2 of 11
(2,380 Views)
What is the point having a For Loop that only does 1 iteration?
=== Engineer Ambiguously ===
Message 3 of 11
(2,357 Views)
The additional FOR loop was sort of a last effort to try and control the data flow, since I suspected that it sampled a timestamp per channel reading. To elaborate: there are 10 channels of boolean data and there is an average of 10x copied of each timestamp. The way I’ve designed it (without the additional FOR loop) is to have 1 timestamp for each data smaple of all 10 channels in the DAQassistant.
Message 4 of 11
(2,330 Views)
Message 5 of 11
(2,340 Views)
Hi, I expanded the millis and it's still identical, It writes the same stamp 10 times and not 10 different timestamps. I'm fairly certain of this.
Message 6 of 11
(2,317 Views)
I never used TDMS files, however I guess you should write the timestamp only once for each iteration of the While Loop, since the acquisition timestamp is actually the same for all 10 channels.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 7 of 11
(2,303 Views)
Accepted by topic author Labviewboyy69420
After some of the feedback and just trying different things I solved it by: Having a foor-loop with N=1 for time (since the timestamp is to be sampled once, then a for-loop with N=10 for the samples, since one stream of boolean values have 10 channels.
Thanks to all for your input!
Message 8 of 11
(2,269 Views)
Hi boyy,
Two comments:
  1. A FOR loop set to iterate just once is most often Rube-Goldberg...
  2. You don't need to set the iteration count (N) when you employ autoindexing of input arrays...
Message 9 of 11
(2,254 Views)
1. The first for loop might be unnecessary.
2. I don’t need to for the loop to funtion. But aestetically on the spreadsheet, this isolates the timestamp sampling from the boolean sampling and results in a single timestamp for all 10 channels per reading (loop count).
Message 10 of 11
(2,248 Views)
